I have a task and don't know the good solution. (I add the picture of my task.) I need to find the right lenght and deflection and to check if the results didn't exceed the allowable stress. I know the value of "q" (force). Also I could choose myself the lenght, but I need to check, if my choice didn't exceed the allowable stress. (The value of allowable stress I also know). But I don't know exactly, which stresses I need to find to compare them with allowable stress?
I have a pipeline and I need to find the lenght and the deflection to keep stresses allowable. My pipe material is Steel ST 37,0. There is one old straight pipe, and we project 200m distance new pipe, and we install it from bottom. And from bottom we connect new pipe with old. We do the same at both size of 200m distance. So I need to find the lenght of that bending and deflection to keep stresses allowable. Pipe dimensions: Diameter DN 300 323,9mm, wall thickness 5.6mm. Also I had calculated already that one metre of pipe weight 43.94kg.
