QuestionBoy
I need to compare the strength of a .5" OD, .040 wall tube made of 4130 with that of a .55" OD, .079 wall tube made of 6061 (the same length, about 4" long). Think of a telescopic motorcycle fork in miniature and you have a good idea what the setup is. I know the bend will be concentrated just below the lower triple tree (or yoke), but it would be helpful to know the approximate force required to bring each material to the yeild point.
I attempted to use COSMOSXpress, but my computer crashes after every attempt. On top of that I'm not so sure I'm setting things up correctly, or that the simulation can be done with COSMOSXpress.
Lives are not on the line with my products, and I don't usually need to do this type of work. However, I'm working on a new product and knowing this basic information could save me some headaches.
Provided I had a computer that could do this without crashing, will COSMOSXpress do the simulation?
TIA
QB
TIA
QB
