NDEs for steam pipe
Davidorias
Industrial
Oct 22, 2002
26
Hello, I would like to know a NDE (Non Destructive Essay)for in-sevice steam pipe, 300ºC.
To answer your question, a lot more information is needed. A comprehensive inspection program depends a lot on the physical characteristics and operational history of your plant.
I assume that this is a probably a carbon-steel steam piping system feeding a steam turbine or similar process component.
For a steam system of this type, both Ultrasonic testing and Radiographic testing are commonly used. In the USA, API-572(?) guideline has been used to set up inspection programs.
My opinion only....
MJC
Thanks, MJCronin. I have been reading an article about laser based nondestructive testing, named shearography. Probably is a very expensive technique, and is probably more addequate for very critical systems.
