Bagman2524,
You could use Ground-Penetrating Radar or electromagnetic sensing to determine the layout of steel in the slab. This should help indicate where the piles are.
You can then sawcut around selected piles to conduct pulse echo tests to evaluate the length and/or shape of the deep elements. Alternatively, you could perform small-diameter corings or borings to evaluate the pile characteristcs.
Jeff
