Hi guys,
Would greatly appreciate if I can get a feedback regarding a query on pumps which comes out of failure recurring failures of multistage pumps
This is a situation from a wet crushing plant. There is a raw water process that supplies water to a raw manifold ( a massive pipe manifold). This manifold supplies water to 13 other pumps, all of which might not run together always at the same time. So there is varying number of pumps running. All pumps are different and have different operating points (flowrate and TDH).
Among these 13 pumps getting supplied by the manifold, there are two multistage vertical axial pumps which are parallel and are supplied by a common line coming from this manifold. My query is - if say the pressure in the manifold is 50kPa, then does the flowrate through any pump, say these multistage pump, depend on the number of pumps (connected to the manifold) operating. That is, if there are 5 pumps operating along with this multistage pump then will the flowrate be different if compared to the case when all 13 pumps were running?
