cnc07
Aerospace
- Aug 14, 2007
- 46
I have developed some algorithms for a high speed smooth tool-motion. In Catia I create lots of cl drive geometry(surfaces, curves, etc..) and then I drive them using Catia's existing tool-path commands such as Profile-contouring, Multi-Axis Flank Contouring etc.. But Catia doesn't offer enough APIs so extra work has to be done interactively even if you use such automation in their machining workbenches. So I decided to buy NX and use my automation there hoping it has more APIs available in it.
I was looking for a Total Machining package NX13430 and it turned out to be an Almost Total Machining because there was some extra modules needed for what I want to do.
I would like to know what exactly this module/option NX30104 provides extra on top of Almost Total Machining? In Catia I can build any automation using VB and sell it to any other Catia user. And I don't have to pay anything to Dassault since my EULA allows me to do that. I was under this impression that NX would allow you to do the same but I guess there is always a catch.
Also I would like to know if user can select lots of curves(roughly over 1300) in one shot and drive the cutter on them? I have a 8.5 learning edition on my machine and I could not find any way to select such guide curves in one shot. All I can do select them one by one. To me it is not an efficient method. I was hoping there is some additional Mill-Geometry container similar to Mill-Boundary where user simply selects and stores all the cl curves in one shot.
For example I have done some Vacuum fixtures this year. In Catia all I did is select the entire set of curves in one shot by a window selection method or I could select them from the Tree in any given Geometrical Set. I was looking this type of functionality in NX but I didn't find any so far.
Thanks,
Singh
Thanks,
Singh
