During analyzing soil resistivity values, the utility had the following criterion:
"For soils with resistivity value less than 500Ohm-meter, if the difference between the highest and the lowest readings are within 30 % then the soil can be considered as uniform soil. For soils with resistivity value greater than 500 Ohm-meter, if the difference between the highest and the lowest readings are within 20 % then the soil can be considered as uniform soil."
I couldn't locate any reference recommendation to that, any ideas?
