design P = 200-psi
do repairs or complete replacement of a 1-inch internal boiler mud drum pipe (used for keeping boiler warm) require to have R-stamp? method of connection is unknown as OEM dwgs do not exist; however, the connection joints may be threaded with seal weld.
I'm thinking no different than replacing boiler tubes in steam generator section; just do not grind/remove pressure boundary metal.
I'm going through section 1 and not able to locate much on internal piping; perhaps I'm overlooking matters.
thanks.
thanks.
