Moving the Schematic Blocks Library
EricatNordic
Marine/Ocean
I've got one node locked V18 full version and 2 V19 2d users that are just getting started. I'd like to move the symbol libary from my harddrive to a server so they can access it too. Will that screw up the way SE works? Is there a particular way it needs to be done?
Selecting the file and dragging in blocks shouldn't cause any problem.
Just make sure they don't open the library dft files and save them otherwise you (V18 computer) won't be able to use those block libraries.
