fer72
- Oct 3, 2006
- 6
I have done modal analysis of vertical pump. The problem becomes when I compare the results of my model with the results provided by the manufacturer 15 years ago.
Basically in my model the 1st frequency of the shaft is twice the frequency given by the manufacturer. I can get this result modelling the shaft supported in two points, but Idon’t think that this is a good approach. I model the shaft inside the pump using beams and them attach the beam to the bearings using two points per bearing, one at start and another one at the end, releasing the displacements and rotations in these points in the axial direction except for the trust bearing.
Has anyone model a journal bearing this way? How were the results compared to frequencies measured in service? Any other options to model the bearing without taken into account tribology?
