I am integrating a proprietary controller into a system that uses Modbus TCP. I have discovered that this controller does not have Modbus function code 4 implemented, and therefore I can only use it to read holding registers. Anything stored in an input register is inaccessible. My slave device has some values stored in input registers that I need to read.
Is it common to not have function code 4? I will need to speak to either the manufacturer of the proprietary controller, or the manufacturer or my slave device and have them make changes and I am trying to decide who should make the change. Foretunately I have a good relationship with both and I have the choice.
