Hi all,
I have some confusion on minimum required thickness of pressure vessel as per ug-16(b), which state that the minimum required thickness for unfired steam boiler and compressed air service or water service is 6 mm and 2.5 mm. But my vessel is used for curde oil service. so, which one I want to take as minimum required thickness as per code.
At the same time I have calculated the design thickness by using UG-27.
