At what depth does the fluid level in a pipe produce waves resulting in slug flow? It seems to me that a thin film of fluid on the bottom of a pipe can not result in wave formation. But for a given high velocity at some point there is enough fluid (liquid hold-up, void fraction) to produce a "dangerous wave". Can a fluid depth of 1/4 inch produce a wave higher that twice that depth? Does the fluid depth, need to approach 1/2 the pipe diameter for slug flow to be a possibility?
Example 1: Steam distribution pipeline, 12 inch S40 pipe, with 125 psig saturated steam, good quality (above 90%), pipe sloped 1" in 20 ft down in the direction of flow (co-current two-phase flow), drips spaced every 500 ft (on the long side, but not uncommon), during warm-up the condensate rate is about 4.1 gpm (~60 fpm) at the dripleg, the condensate depth is about 1/2 inch, the steam flow is near maximum and at 12-15,000 fpm velocity. At running load about 0.08 gpm (17 fpm) and condensate depth of 3/32 inch.
Will slug flow be a possibility? What height waves could be generated? Will the outcome be some small waves which crest and disperse more moisture into the steam?
Example 2: Same as above, but now the slope is up in the direction of flow and we have counter-current flow. What happens in terms of slugging, waves, moisure level?
My understanding is that the flow regime is not annular given the low fluid volume and the relatively low velocity for multiphase flow. So, we are probably dealing with stratified smooth, stratified wavy, slug, and dispersed regimes and transitions.
I've been chewing on these nuts for a while, and would like to get them as digested as possible...
