msii
- Nov 1, 2017
- 44
Hi Guys,
I' m struggling with an issue regarding bolt minimum acceptable pretension. I'm designing a clamp for aluminium tube (DN 50)and I'm using finite element analysis to check bolt loads and loads on tube. Bolts are M5 and if I follow available bolt pretension suggested by different manufacturers and charts Aluminium tube would collapse due to high pretension even if I increase thickness of tube. In this situation I want to know what minimum acceptable bolt pretension is to avoid loosing clamp and keeping clamp in its place.
Schematic shape of clamp is presented on below website:
please note "C" value should be 2mm.
Thank so much
Thank so much
