I've used ACAD since v4, so I admit I am biased towards it. I have always been able tu pick up ANY software just by using it (including autocad v4, MAX, quark,...); However I have never been so frustrated by using a software as I have been with Microstation. No feed back on what is going on, sometimes yo have to left click to accept, sometimes you don't, it depends on the tool and on what's selected. Tools and menu not working properly and not updating to what's is currently selected, bugs, limited to 63 layers (NO it's not enough, even if there is WORK-AROUND by using reference file, which by the way are also limited in number!)
People say it's more like drawing, or like illustrator, but hey! it's very far from wysiwyg: lineweights are not representative, even linetypes aren't! I'm sure experts would know which variable to change to make a linetype look different, but I don't!
Palettes that reset every time you open a drawing, layers without names, complicated plot dialog, Options and variables for one fuction spread all over the menus, unintuitive menus, non-eplorer-like File Open dialog boxes which prevent you from seeing file properties, Network Drives displayed as a letter only instead of it's name, cells limited in size, cells you can't update easily
Everything is complicated, and just thinking of the process I have to go through to make the simplest things just frustrates me.
Let's take an example: I want to change the color of a line I see on screen.
1 - Click Select tool
2 - click on empty space to make sure sure I haven't got anything else selected, or beware of nasty surprises!!!
3 - Select change attributes tool, click Color Tick mark and select my color
4 - click on the line
5 - click to accept
6 - Oops it's not doing it! Why? WHY?
7 - check that level symbology is not on
8 - check that the line is not a cell
9 - go to Information and click on line
10- Scroll all the way down to figure out if it's in a reference file
11- AAh it is. File 6 whatever it is, it doesn't actually tell you, which would be useful so that I could open that file and modify the line.
And by the way, why is the Change attributes tool allowing me to select that line in a reference file if I can't modify it! And no warning whatsoever.
12- open reference file manager
13- select file 6 and Exchange
14- Select change attributes tool
15- click on line
16- Nothing happens, Oh i have to select Color Tick mark and select my color once again, (palette has reset to default)
17- Ok It's done
18- Go back to original file
19- the line has changed color but it's the wrong one, there is probably a different color table for that file than for the current file
20- and on and on and on
This is scary! Don't you realise this.
Let's see this in Acad
1. Click on line
2. oops the whole draing is highliting, must be a block or a reference file. (if you have your properties palette docked in, you can see it straight away and go to step 4.)
3. LI - click on object again.
top of the window: x-reference = filename.dwg
Either user refedit real simple, but I'm old schools so
4. I'll open the drawing, (If I don't know where it is saved, go to Reference manager and copy the location, go to file open and paste it in.)
5. Click one the line, go to Format (as in any other windows menu) properties (as in any other windows menu) change the color.
6. Go back to my drawing
Done
Except for step 2. never any hesitation or frustration
