M
MRTH
Guest
I have been trying to get a contact analysis of a shrink fit joint to work, but I have the following problem:
Theautomesh does not work well with overlapping geometry, if the overlapping is too small. In this analysis the overlapping is 0.7 mm for a diameter of 570, if I increase the overlap to 3, the meshing appears to work. I have tried to change the autogem setting but I have not been able to find the right parameter.
Does anyone out there have experience of this type of problem?
