ryanwolff90
Hi All,
Our machine uses compressed dry air to power certain sub-systems (pressurized systems such as isolation, or hydraulics) and as cooling air for hot items. If I measure the airflow coming from the regulator at the wall to the machine by installing a flow meter in line, I am measuring the actual flow rate at the line pressure set by the regulator, correct? And I would need to calculate the standard CFM by normalizing the pressure and temperature down to STP, 14.7psi and 68F? I guess I am confused because the King's flow meter I bought says SCFM on it. I didn't think measuring flow with a flow meter would give me SCFM, only actual CFM at pressure, unless I was measuring the airflow going out to the atmosphere.
Thanks!
Ryan W.
Thanks!
Ryan W.
