Measure the distance of an arc (line) from point to point?
junfanbl
Marine/Ocean
Jun 10, 2015
90
Is there a way to measure the distance of an arc in a pipe? Obviously you can't use the measure tool because it only supplies a straight line. Any other suggestions?
If you have the centerline of the pipe, you can use the measure -> length tool. It allows you to select one or more curves and reports the combined length along the curve/combined path.
www.nxjournaling.com
