Maximum impact test energy
ElCidCampeador
IT
Hi, I have a certificate of a plate, A 240 TP 316/316L thk.15mm, Rm=570 MPa, Rp0,2%=298Mpa, HB=169 Brinell, with Absorbed energy of Impact test 450 J.
Ok, it's stainless steel, but I think this value it's too high... What dou you think? Is it possible?
At what temp? AT low temp yes I would believe it.
The austenitic stainless steel materials can have CVN values this high.
Hi ElCidCampeador,
in the scope of ASME BPVC and piping codes for evaluation of impact test values there is no requirements for absorbed energy. There are only requirements for the minimum lateral expansion opposite the notch, e.g. :
[ul]
[li]ASME VIII/1, UHA-51(a)(2)(-a) shall be no less than 0.38 mm (0.015 in.), when the MDMT is −320°F (−196°C) and warmer,[/li]
[li]ASME VIII/2, 3.11.4.1.(b) shall be no less than 0.38 mm (0.015 in.), when the MDMT is −320°F (−196°C) and warmer[/li]
[li]ASME B31.3, Table 323.3.5 shall be no less than 0.38 mm (0.015 in.)[/li]
[/ul]
In the scope of ASME BPVC, if on the above mentioned certificate the lateral expansion is not stated this certificate have to be rejected.
But acc. to my experience after rejection you will get immediately a apology by the material manufacturer for the spelling mistake and a new certificate with beautiful lateral expansion values.
Regards - Juergen
450 J @ -50°C
Is there a way to check if this is a true value, knowing the standard tensile properties?
A tensile test is for the strength and stiffness of the material, Charpy impact test is a cheap way of measuring/correlating to material toughness.
Which location is this test for, how many samples at this location were tested and what energies were achieved? It's common to have a significant scatter in impact energies for a similar test location.
No. Additional CVN testing would be required of the heat of material.
See SA-240
S1.6 Records—The recorded results shall include the
specimen orientation, specimen size, test temperature, absorbed
energy values (if required), and lateral expansion
opposite the notch.
r6155
450lb-ft sounds like it may be the max of their machine, I have seen people forget the ">" sign when you max out an impact test.
I have seen this happen on 600lb-ft machines testing duplex stainless, the pendulum just stops, and you ruin the striker.
At -50ºC SA 240 316/316 L impact tests are exempted. See UHA-51.
Try to avoid problems and waste time when tests are not required.
r6155
Thank you all.
Singular value of absorbed energy are 449, 450, 449. Lateral espansion, average value, is 2,29 mm
The test was taken after solution heat treatment (it's a test coupon of a formed head): may the heat treatment increase the absorbed energy?
@r6155
Wasting time? I know UHA-51, but impact test IS required by client despite of exemption by code.
What is the minimum value of impact absorbed energy required by Client?
r6155
Austenitic materials are generally recognized for their lack of ductile-to-brittle transition behavior. In other words, they do not generally display a reduction in impact energy as the test temperature is reduced. By contrast, ferritic and martensitic materials-such as the carbon steels, alloy steels, and 400-series stainless steels-exhibit reduced toughness as test temperature is reduced.
Hence, ¿wasting time?: YES
r6155
While your Client is wasting his money, you have satisfied his requirement. And as others have stated, those absorbed energy values can be achieved.
My point of view is ethic. I try to convince my client to save money and time. I gained several clients in this way.
r6155
You now have more ammunition to convince your client that he is wasting his money, but as this old saying goes, "You can lead a horse to water but you can't make him drink."
