Hi ElCidCampeador,
in the scope of ASME BPVC and piping codes for evaluation of impact test values there is no requirements for absorbed energy. There are only requirements for the minimum lateral expansion opposite the notch, e.g. :
[ul]
[li]ASME VIII/1, UHA-51(a)(2)(-a) shall be no less than 0.38 mm (0.015 in.), when the MDMT is −320°F (−196°C) and warmer,[/li]
[li]ASME VIII/2, 3.11.4.1.(b) shall be no less than 0.38 mm (0.015 in.), when the MDMT is −320°F (−196°C) and warmer[/li]
[li]ASME B31.3, Table 323.3.5 shall be no less than 0.38 mm (0.015 in.)[/li]
[/ul]
In the scope of ASME BPVC, if on the above mentioned certificate the lateral expansion is not stated this certificate have to be rejected.
But acc. to my experience after rejection you will get immediately a apology by the material manufacturer for the spelling mistake and a new certificate with beautiful lateral expansion values.
Regards - Juergen
