Looking at the Australian residential masonry code (AS 4773.1), at the section on single leaf, unreinforced walls. The requirements for internal walls seem quite vague, giving only a maximum height for different brick thicknesses:
"Internal single-leaf masonry walls shall be at least supported at the top in accordance with Clause 6.4 and shall be dimensioned in accordance with Table 9.3"
The table states that 90mm thick masonry can only be a maximum of 2400mm high, whereas an external screen wall can be up to 3000mm high. I would have thought that an internal wall supporting a concrete slab would be able to be used for 3000mm panels, and I am sure that it is done regularly.
Does anyone know the basis for this requirement, and do you adhere to this?
