Masonry Stem Walls - commercial construction
Ben29
The below detail is from IRC. I personally have never designed a masonry stem wall like this for a commercial building. Is this ever done?
I have a client that wants to install an 11'-5" tall wood stud wall on top of a 3'4" masonry stem wall. The roof truss bearing elevation is 14'-9". I'm not very comfortable with this idea. They want to do it to save money on masonry, but I feel that any rotation in the top of that masonry stem wall will cause issues for the wood framed wall and roof above.
Stop looking at the IRC and design from first priniciples.
I usually design the footing extra wide and add a bunch of rebar despite what the numbers say.
Thanks XR. I just referenced the IRC because they had a handy detail which illustrated the concept of what I was talking about.
That detail is all about lateral loads from a portal frame built per braced walls. It does absolutely nothing to counter the rotation your concerned with. That has to be handled separately.
In your case, you'll have a standard wood wall attached to the top of a cantilevered masonry wall. From top to bottom, you'll have pin, hinge, fixed. If you draw that free body diagram, you should see that it's stable. Now, design each component accordingly.
