I guess I was referring to his initial question about fuel gas. In my experience with the fuel gas systems around here they are usually (now THERE'S the watchword) bone-dry. I don't remember the PG&E/SOCAL spec for lbm moisture/MMBtu around here. And, my experience is limited to pipeline spurs and on-lease/in-plant distribution systems of, at most, 20 miles in length.
While we always install scrubbers just downstream of the onsite PRV stations and the burners on various fired equipment I have yet to see one of them dump any liquids. Not saying they won't, though, and I don't live in front of a gas scrubber, so... Your points are well-taken. Just be sure you can justify the expense on beefed-up supports and scrubbers.
As I said, this is a trade-off and the selection of flow rate thru a known pipe is not a trivial question and is certainly more complex than a V=Q/A analysis.
Don't you just love the real world? As one of my profs used to say - Life is a hard teacher - it makes you take the exam BEFORE you've had a chance to study . . .
zdas, where are you at? I did quite a few projects at the MCU when I was with Mobil. I always loved going there and always made it a point to stay over an extra day to drive around and check out the sights. Beautiful country around there. I would move to Cortez in a second if my wife would go there. Thanks!
Pete
