MAWP Calculation
Rajeev Kulkarni
IN
Clause 6.3.6 specifies that ''MAWP shall be at least the maximum discharge pressure plus 10 % of the maximum differential pressure''.
My Question is:
For calculating ''maximum discharge pressure'' or ''maximum differential pressure'', do we need to consider the Shut Off head Test Tolerance provided in Table 16?
My understanding is that the 10% margin specified in Clause 6.3.6 takes care of the excursions and an additional Test Tolerance as per Table 16 is not required / applicable.
6.3.6 of what? Your specification?
They seem thought tobe referring to the same thing for most, but not all pumps.
SO max Diff pressure might not happen at zero flow, but if it did then its the same thing.
What does the definition section say?
MAWP >= MAX Discharge Pressure + 10% Max differential pressure.
Since
Max Discharge Pressure = Max suction pressure + max Differential Pressure
Then
Max suction pressure + max Differential Pressure + 10% of max differential Pressure
Making your specified MAWP
MAWP >= Max suction pressure + max Differential Pressure + 10% of max differential Pressure
MAWP >= Max suction pressure + (1.1 * max Differential Pressure)
Maximum differential pressure occurs at the flow rate as seen on the pump curve.
Note that all pumps do not have their max dP at 0 flow, especially PD pumps.
Assuming this is API 610 I think you've misunderstood table 16. That appears to list the acceptance criteria for testing the actual compared to the theoretical.
You should be using the actual if at all possible.
But this is only 10% tolerance so the 10% for MAWP is only 10% of that so only 1% in total.
Not going to be important.
