master cam x rough pass
  • Thread starter Thread starter bissen00
  • Start date Start date
B
bissen00
Guest
i am a high school student and am trying to cut a letterd piece out of steel and i need to roughit down with a .25 inch endmill but i can not get it to leave extra stock around the letters to come by with a finish pass and a 1\8th inch endmill the teacher said that it will break if i try to do it all with a 8th inch endmill. is any one familiar with mastercam x and no how to do this none of my teachers no how to do it? all help would be appreciated.
I believe you are in the wrong forum, this is Proe
thats why i am here i no what i am doing but this is not working you guys no how to do it alot better than me
bissen00 -
To clarify, are you looking for help in creating toolpaths using Pro/Engineer, or Mastercam? There are different forums for each, and it appears that you are looking in the wrong location. if you would like assistance with Pro/Engineer, then we'd be more than happy to help. If you are looking for help with Mastercam, you would be better served by asking your question in that forum.
-tsl
okay wrong forum but ..
2 ways
one..use the multipass option on contour.
two...xy stock to leave on, add what you want, then copy the cutter path and
change to zero
