RFreund
- Aug 14, 2010
- 1,885
How is reinforcement generally spaced or placed in the field when the wall length does not match the spacing? Say you have a 12' long wall with 32" oc spacing. So there are 18 cores so every 4th core would have a bar plus one at the beginning and one at the end.
Does the reinforcement get laid out starting at one end working toward the other so that at one end there is a bar in adjacent cells? Meaning there would be a bar in core 1, 5, 9, 13, 17 and 18. Or do they work toward the center or try to adjust the spacing some other way? Is there a standard?
I'm trying to match the calculation to what will happen in the field or atleast make it conservative so that the layout really doesn't matter.
Thanks in advance!
EIT
Thanks in advance!
EIT
