make a program in mathcad
sjjustine
Chemical
GB
I what to make a program in mathcad which can take any matris values, let say first matris is{10,20,40,50} and apply it in the eq. Y=constants x matris values then take Y to the next eq. which is m= Y/another constant. I am after m values, which then will be plotted against time. What I want is to be able to add as many matrises as possible and automatically recieve different m values for each added matris without need to rename things when I am using the same eqautions. I just what to find away to simply things.
HELP!!
Is this a real time, on-going calculation or to analyze results from a finite time period? If it is to analyze results, an Excel spreadsheet organized by columns or rows may do just as well since you aren't inverting matrices.
If not, more details and background may be helpful to better answer the question.
