yoshimitsuspeed
Automotive
Does anyone know of any good articles, studies or threads discussing main/rod bearing diameter and friction?
And or is there a formula to ballpark the friction related to RPM?
The next part of the question is around other variables. For example I'm thinking that if you had two rotating assemblies, otherwise identical in weight and dimensions with the same width bearings and one with a wider journal couldn't you run a little lower viscosity oil because of the increased surface area? How much effect would this have on the friction? Are there other variables that could allow a bigger crank reduce friction due to the added area?
And is the increase in friction related to RPM pretty much constantly linear or is there a point at which RPM or journal surface speed starts to have an increasing rate of friction?
