CamTheNewby
I am looking to set up a small test to calculate the performance capabilities of a rotary valve, and modify the part for optimal performance based on the test results. Part of the system will require a pump. I have never really looked into purchasing a pump myself, but I do know what kind of requirements there are for the system. I want it to run in a closed loop if possible, no check valve required ideally. Also, I want to test it while the valve inlet and outlets are subjected to a range of different psi pressures ranging from around 60 or 65 psi, to about 100 psi. I am hoping to just be able to leave it, so that the pressure remains at a steady psi pressure, and I can just leave it over night to run. I don't know if this would effect the choice of parts, but the diameters of the inlets and outlets are around 1.6".
Could anybody recommend what kinds of pumps/lengths of hoses or pipes would be good for this kind of experiment? I was thinking about an impeller pump of some sort, and a non-positive displacement. Any suggestions would be greatly appreciated. I'm pretty new to this stuff, so please excuse me if I sound like I don't know what I'm talking about because I don't really haha. Anyways, thanks!
