looking for a manufacturer of special castor-bearings
Lotusbert
Industrial
May 22, 2003
8
I'm looking for a manufacturer of special bearings who can make me the following
-a double row ball bearing, dust sealed, OD 36 mm, length outerring 30 mm, ID 8, length innerring 34 mm, min diameter of innerring aprox 17 mm, load capacity ca 90 kg at 200 rpm
this is the kind of bearing used in castors, lawnmower-weels etc. also used in waterpumps but with a plane axle instead of a innerring (tube)
Thanks for the replies
There are hundreds of manufacturers of the type bearing you require and the easiest way is to do search for water pump bearings on Google.
Here is a website supplier I’ve used for some odd bearings.
