Attached is a sketch for trying to locate a hole relative to another hole that is in a different plane with a looser +/- tolerance. Essentially what I am trying to say in the FCF is "this hole is to be parallel to A and located vertically from it's respective basic dimension, it's center is to be in line with the center of the looser hole, and it is to be parallel to datum C with a location tolerance of .005"
I hope that makes sense and sorry if my wording is a little weak (in the process of learning). All comments and questions are most welcomed.
Thanks,
Greg
Thanks,
Greg
