truckdesigner
AS4991 (Australian Standard) Lifting devices states that:
Where a lifting device is being used for general application, it shall be capable of withstanding -
a) a minimum design load of 1.5 times the capacity.
But then states:
Lifting devices shall be proof loaded in accordance with the following:
a) Up to 10 t.............2 x working load limit
b) 10-160 t...............(1.04 x working load limit) +9.6 t
c) Above 160 t............1.1 x working load limit
So:
If I design something for a WLL of 5 Tonne, it will be actually designed 1.5 x 5 Tonne = 7.5 Tonne.
Then to proof test it I have to test to 2 x WLL = 10 Tonne.
The design is to be in accordance with AS1418.1 Cranes, hoists and winches which calls up AS3990 Working stress design OR AS4100 Limit states design. In this case I have used AS3990.
My question/s:
Am I thinking correctly?
Is this standard flawed?
Will the structure fail at a proof load of 10 Tonne? (Don't think it will).
Can someone with greater knowledge than I please explain the theory here? I just don't get it!
Regards.
But then states:
So:
My question/s:
Regards.
