Load cell/force sensor 500-1000k load rating
Vyasas
I am looking for a force sensor/load cell with 1000k-500k load rating. This will be used in a impact application. Static or dynamic does not matter.
Any help will be greatly appreciated.
THanks
try googling before asking for help ... a simple google "load cells" turned up many usefull looking links, very little more digging found several load cells rated for 1,000,000 lbs
Tons of companies manufacture load cells in your range requirement.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of these Forums?
FYI, a load cell is not a great device for measuring dynamic loads unless you compensate for the inertial acceleration of the load cell.
