woodman1967
- Feb 11, 2008
- 84
In this particular opening the existing masonry wall is 16" thick. I've never designed a lintel for such a wide wall.
The opening is only 7' wide, but the opening is located at the corner of the wall so there will be no arching effect. Anyway, what would you use typically in this situation? I've looked at two W shapes side by side but that made connections tricky. I am looking for a solution using steel.
Thanks for any suggestions
