Sparweb
Aerospace
- May 21, 2003
- 5,180
Is there any way to manage complex LOD's without activating them?
I would like to be able to inspect and control a list of suppressed and unsuppressed components without having to activate the LOD.
Level of Detail is the only way I can get my models to open. I design structures and systems within a model of aircraft structure that consists of about 100,000 pieces. This would take hours for my computer to open if I opened it explicitly, or if I insert it into a model with all of its components active. However, by careful use of Level of Detail, created first in the aircraft IAM model, then used and reduced again in LOD in my own IAM models of systems, I can avoid having models that take a very long time to open when I work on systems.
After enough time goes by, however, changes to other systems in the aircraft IAM model provoke changes that propagate to my models. There are a dozen other designers working of different structures and systems, and we all reference the same aircraft model structure. Each of use creates the LOD in the IAM we are working on.
I currently have a model of plumbing that I can't open because the aircraft model has changed so drastically that the LOD I created isn't valid any more. What causes Inventor to have this problem, I can't explain, but it's trying to open MASTER. I can open the file with Options-All Items Suppressed. But I can't activate any of the LOD's already in the IAM because Inventor doesn't know what they are any more, so Inventor starts loading the MASTER aircraft.
I do not want to rebuild all of the LOD's in this model from the bottom up! That would take hours, and the drawings that reference this IAM are corrupted unless I can fix this.
STF
STF
