lets say customer can only send you a faceted body
fzvnpg
New member
am I just out of luck?
is there any way to convert it to anything I can use?
UG is my only system so help me out and how can I use, convert, copy, link , extract this into NX7.5????????
Cj Silver
Senior Tooling Engineer
GKN Aerospace
Working to remember all I forgotten
an .obj or stl?
Cj Silver
R&D Engineer
If this is a purchased item, you can simply add it to your Assembly as a faceted Component. However, if it's something that you need to add to or modify then you really need to have them provide you with a solid model. Converting faceted bodies into solids is not easy and unless it's a freeform shape, the level of accuracy of the 'converted' model may not be sufficient so that it's usable as an actual design model.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
its a shape that's 3d and I need to modify it and smooth it
so I guess if there is anyway to convert it even with lose of detail i'd take it
cause now I got nothing
Cj Silver
R&D Engineer
Do you have access to a "shape studio" license? If so, have a look at the rapid surfacing tools. It can be tricky to use, but is intended to help create surfaces from faceted bodies.
www.nxjournaling.com
It depends on the stl file and the shape of the part. John is correct that you may loose accuracy.
2 programs that I use are Rhino 5 and Spaceclaim 2014 with varying results. There is another program called Verisurf but I have not used it.
TheeCircle
Cj Silver
R&D Engineer
sorry let me try that again
Cj Silver
R&D Engineer
It will not download. You need to upload it to the Engineering.com site I think?
doesn't that leave it a faceted body though....
need to clean and trim and fix this shape int a usable product instead a pretty 3d picture
Cj Silver
R&D Engineer
it did indeed bring it in a faceted body and I importing it and should be translating it in?
Cj Silver
R&D Engineer
I agree but if I can get it into nx I can rebuild it but have to have something to start with...
thanks all guess I am out of luck
its the best scan from customer and they brought it together with maya
Cj Silver
R&D Engineer
Here's what i get if i import the .obj file into Rhino, in Rhino convert the "mesh" into Nurbs. Export to Iges and import the Iges into NX...
( The export tool in Rhino isn't perfect, it didn't export everything as Iges , so i exported "everything" again to Step, and then it only exported what the Iges missed... :-)
Since the "mesh" consists of "planar" rectangles it becomes converted into Nurbs degree 1x1 faces. ( the rectangles can be twisted.)
If it can be used i don't know, might be better than the facets.
Tomas
 http://files.engineering.com/getfile.aspx?folder=5fc9030e-b9d8-4163-b49f-f9ed0dd60099&file=green_sulky_igs.zip
thank everyone for going above and beyond on what should have been so easy and yet as you showedwas not
thanks everyone
Cj Silver
R&D Engineer
I got about the same results as Toost using Rhino.
