We are having aproblem with amechanical-seal that keeps leaking on aJohnson FREF pump (Free Flow Centrifugal pump with an extended shaft). The pump is used to clean chemical tanks with water on a ship. The old seal was broken, not completely worn, and the retainer bold of the impeller was broken. Although there was no visible damage to the impeller (possibly it just stayed in its place) we installed a new impeller, seal and mechanical-seal. When the pump was reinstalled on the ship it kept leaking. The pump runs at a constant speed and ofthen has to operate with its discharge trottled (when cleaning only one tank at a time). The ships crew filled the compartiment that holds the mechanical-seal with oil, is this correct? It was this oil that came out through the vent hole, and then after this water came out. When the pump was reopend no significant problem a new damage was found. We did observe that the sealspring was only being compressed for about 1.5 mm. Is this enough for a spring that is +/- 20 mm. long. We also found that the extended shaft was bend 0.1mm. But no vibration occured when we ran the pump. Then a college of mine installed a (self made) shim behind the pumps backplate to increase springpressure. This cured our leaking problem but this olso affected impellerclearance with a pressuredrop of about 2.5 bar (cavitation?). Anyway the leak came back after a day. Seals were checked for size and lenght and spring stifness and as far as we can see they are the same. So wehere do we look now?
