HarryRai1984
This post is just to see if someone can clarify a confusion I am having at the moment...
I want to design a DC-DC converter which takes a 12V, 20mA DC input and converts it into a 5V, 0.5A DC output.
I have looked at LDO voltage regulators like the LM2940CT-5.0 and LM7805. My confusion is over the Quiescent / Ground Current that is needed to power the Regulator and supply the 5V DC output rail.
Am I ok to use a LDO Voltage regulator to drop 12V to 5V DC??? Or am I overlooking the fundamental fact that my LDO can get 20mA only from an external Power Supply and then needs to generate a much higher power output (5V @ 0.5A), so I need to use a different topology to boost the input DC voltage??? Something like Boost Converter???!!!
Power wise, on the input side, you have 12V x 20mA = 250mW and output side has 5V x 500mA = 2.5W (so 10x input power available!!!)...
Any guidance would be appreciated...
Harry
Harry
