Laboratory tests for Lube oils 1
shipvibration
Marine/Ocean
MY
where can one find all the tests (coded by ASTM)for various Lubricating oils and Fuel oils?
thanx
If I understand the question you need a list of some testing commonly done for liquid fuels and lubricating oil. ASTM have an extensive list of hydrocarbon tests. You can find the numbers with a brief summary on the web. The ASTM site gives a summary paragraph about the individual standards but not the test itself. For access to codes and standards we use a service from IHS (Information Handling Services) to access the text of many codes and standards.
ASTM tests include ASTM D129-00 01-Nov-2000
Standard Test Method for Sulfur in Petroleum Products
ASTM D130-94 01-Nov-1994
Standard Test Method for Detection of Copper Corrosion from Petroleum Products by the Copper Strip Tarnish Test
ASTM D6304-00 01-Aug-2000
Standard Test Method for Determination of Water in Petroleum Products, Lubricating Oils, and Additives by Coulometric Karl Fisher Titration
ASTM D1500-98 01-Nov-1998
Standard Test Method for ASTM Color of Petroleum Products (ASTM Color Scale)
Also IP 196/97
Keywords: ASTM color; color; petroleum products
ASTM D156-00 01-Aug-2000 (Product, gasoline, jet fuel, kerosine)
Standard Test Method for Saybolt Color of Petroleum Products (Saybolt Chromometer Method)
Document Number: ASTM D1796-97
American Society for Testing and Materials
01-Nov-1997
Keywords: centrifuge; fuel oils; toluene saturation; water and sediment
Standard Test Method for Water and Sediment in Fuel Oils by the Centrifuge Method (Laboratory Procedure)
ASTM D1837-01 01-Aug-2001
Standard Test Method for Volatility of Liquefied Petroleum (LP) Gases
Keywords: butane; liquefied petroleum (LP) gases; propane; LPG; volatility
Particle classification is among the tests for lube oil system cleanliness. Several particle counters such as the UCC CM20 exist. These counters identify the lube oil particles by size and quantity. For each size group the counter gives NAS classification. You may need a vacuum pump to remove air bubbles that read as particles. The cost for such a counter begins under $10,000 US or can cost over three times as much depending upon your specific requirements.
The total NAS classification is the largest number. You might look for NAS on the web to learn about the Aerospace Industries Association NATIOMAL AEROSPACE STANDARD AIA/NAS NAS1638 92. ISO standards also exist. The particle counter can display ISO results too.
You can buy a book with most of these ASTM standards or obtain only the standards of interest. This should help start the search.
John
