We have an application with a rotating horizontal shaft with overhung weight. We must weld a corrosion-resistant collar of 316L combination bevel/fillet welded to the 1018 shaft and due to the overhung load these welds are machined and polished. The collar is long enough vs. it's thickness that it is not full penetration welded.
Now we have an esteemed customer who requested 4140 instead of the 1018 carbon steel and our spec review did not catch this stipulation. Unfortunately there are ways to make 4140 and 316L stick together with welding tools (note choice of words) with no discussion of joint strength and I'm seriously concerned that doing this in this application will result in high notch sensitivity, corrosion sensitivity, and fatigue failure. While stress levels are low the stress is pure alternating fatigue.
Is there a welding code that could provide guidance (a categorical "no!" is acceptable) about the proposed 4140/316L design? I see a lot of information out there about how to weld 4140 but not related to 316L and highly stressed joints.
Thanks,
David
Thanks,
David
