Journal to set/ change dimensions tolerance
niedzviedz
307
I want create journal to automatically set (or change already setted) dimensions tolerance. The macro must have:
1) possibility to select more than one dimension
2) possibility to reset previously setted value
3) possibility to select different kinds of dimension (radius, diameter, horizontal, vertical, parallel etc.)
I already wrote some of code, by the main problem is that, I don't know how fix selection of more than one dimension, and I can't set values.
Below is my code:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Annotations
Module journal
    Sub Main
	Dim theSession As Session = Session.GetSession()
	Dim ufs As UFSession = UFSession.GetUFSession()
	Dim workPart As Part = theSession.Parts.Work
	Dim displayPart As Part = theSession.Parts.Display
	Dim lw As ListingWindow = theSession.ListingWindow
	Dim theAnnotationManager as NXOpen.Annotations.AnnotationManager = workPart.Annotations
	'Dim theAnnotationManager as AnnotationManager = workPart.Annotations
	Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager
	Dim noteDim As Annotation
	Dim Dimension1 As Annotations.Dimension
	Dim response1 As Selection.Response = Selection.Response.Cancel
	response1 = select_Dim("Select a Curve", noteDim)
	If response1 = Selection.Response.Cancel Then
		Return
	End if
' this code is coped from recorded journal
	Dim linearTolerance1 As Annotations.LinearTolerance
	linearTolerance1.LimitFitDeviation = "g"
	linearTolerance1.LimitFitGrade = 6
	Dimension1.SetTolerance(linearTolerance1)
    End Sub
    Function Select_dim(ByVal prompt As String, ByRef obj As annotation)
        Dim message As String = "Select dimensions"
        Dim title As String = "Selection"
	Dim ui As UI = NXOpen.UI.GetUI
	Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
'        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
	Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim selectionMask_array(0) As Selection.MaskTriple
	Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        With selectionMask_array(0)
            .Type = UFConstants.UF_dimension_type
            .Subtype = 0
            .SolidBodySubtype = 0
        End With
	Dim cursor As Point3d = Nothing
        Dim resp As Selection.Response = _
        ui.SelectionManager.SelectObject(prompt, message, _
            scope, _
            SelAction, _
            includeFeatures, keepHighlighted, selectionMask_array, obj, cursor)
	If resp = Selection.Response.Ok Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY
    End Function
End Module
This journal must set dimension tolerance to "g6", but after selecting do nothing.
Could someone can help me improve this code?
with best regards
Michael
What version of NX?
Your code doesn't do anything after the selection step because the selection function is working with the noteDim variable; but the code to change the tolerance is working with the Dimension1 variable, which appears to be a null reference (no value has been assigned to it).
www.nxjournaling.com
I'm using NX 8.5.
So I should change
to
response1 = select_Dim("Select a Curve", dimension1)
or something else?
with best regards
Michael
I changed code to this:
Code:
	Dim Dimension1 As annotations.dimension
		Return
	End if
	With dimension1
		.LimitFitGrade = 6
	end with
but it also doesn't do anything.
I think you are quite a distance from getting a result.
As an example let us assume you have a linear dimension with a limit & fit included.
What is required is something like the following:
1) Create a builder
Dim linearDimensionBuilder1 As Annotations.LinearDimensionBuilder
2) Use the selected dimension in the builder (called say dimension1)
linearDimensionBuilder1 = workPart.Dimensions.CreateLinearDimensionBuilder(dimension1)
3) Set the required parameters
linearDimensionBuilder1.Style.DimensionStyle.LimitFitDeviation = "g"
linearDimensionBuilder1.Style.DimensionStyle.LimitFitGrade = 6
4) Commit the changes
Dim nXObject1 As NXObject
nXObject1 = linearDimensionBuilder1.Commit()
Hope this helps
Frank Swinkels
I think you can get this to work without a builder object; but you will need to make at least 2 changes:
[ul][li]the Annotation.Dimension class has no .SetTolerance method, but many dimension types which inherit from this class do. You will need to use one of these specific dimension object types.[/li]
[li]perform an update after the tolerance is changed. To do so, you will need a reference to an undo mark (whether visible or invisible), see pseudocode below.[/li][/ul]
Code:
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "change tolerance")
code to change tolerance
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.DoUpdate(markId1)
cowski I have some questions:
What is it for markId, it appears in every journal I record.
The Annotation.Dimension class has no .SetTolerance method, but has:
.LimitFitGrade
.LimitFitDeviation
and also has
.SetAttribute(String, String)
.ToleranceType
Which could be used to change tolerance. But I don't know how.
FrankSwinks I will also check Your solution with linearDimensionBuilde. Do You have any examples with this function?
Below is my changed code, but I receive error "System.NullReferenceException reference to object wasn't set to occur in object in journal.main() line 29" (I translated it from my language so there will be some difference in English version). Line 29 is: linearTolerance1 = Dimension1.GetTolerance()
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module journal
    Sub Main ()
	Dim Dimension1 As annotations.horizontaldimension = select_dim ()
	theSession.SetUndoMarkVisibility(markId1, Nothing, Session.MarkVisibility.Invisible)
	theSession.SetUndoMarkName(markId1, "Dimensions Dialog")
	linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits
    End Sub
    '   sub to select dimensions
Function Select_dim() As Annotations.HorizontalDimension
	Dim prompt As String = "Select dimensions"
	Dim obj As Annotation
            .Subtype = 0
        End With
	Dim selectedObject As NXObject = Nothing
        'Dim resp As Selection.Response = _
            scope, _
            SelAction, _
	Dim dim_1 As Annotations.HorizontalDimension = CType(selectedObject, Annotations.HorizontalDimension)
	If dim_1 Is Nothing Then
	   Return Nothing
	End If
    End Function
    End Function
End Module
I changed annotation.dimension to annotations.horizontaldimension. In recorded journal there is a line:
Code:
Dim horizontalDimension1 As Annotations.HorizontalDimension = CType(workPart.FindObject("ENTITY 26 1 1"), Annotations.HorizontalDimension)
I tried change it to set tolerance to selected objects instead first dimension put in drafting ("ENTITY 26 1 1"). I think that the code is almost ready (after eliminate this error), but the main problems still exists:
1) how to select more than one dimension?
2) how to set tolerances to different kinds of dimensions (horizontal, vertical etc.)
Here is a simple demo journal. I have tested it using NX9. I no longer have an installed version of NX8.5 but it should work within its limitations. It works for angular and all linear dimensions. The example code does not include the option to set the limits and fit values but is fixed in the sub. It does work on these types to add or edit the limit and fit data.
Hope this helps.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module EditTolerance
    Dim s As Session = Session.GetSession()
    Dim ui As UI = UI.GetUI()
    Dim workPart As Part = s.Parts.Work
    Sub Main()
        Dim selecteddim As NXObject = Nothing
start1:
        response1 = Select_dim(selecteddim)
        If response1 = Selection.Response.Cancel Then GoTo end1
        EditDimensionTolerance(selecteddim)
        GoTo start1
end1:
    End Sub
    '   sub to edit tolerance
    Sub EditDimensionTolerance(ByVal selecteddim As NXObject)
        Dim dimname1 As String = selecteddim.ToString
        If dimname1.Contains("Radius") = True Then
            Dim radialDimensionBuilder1 As Annotations.RadialDimensionBuilder
            radialDimensionBuilder1 = workPart.Dimensions.CreateRadialDimensionBuilder(selecteddim)
            radialDimensionBuilder1.Style.DimensionStyle.ToleranceType = Annotations.ToleranceType.LimitsAndFits
            radialDimensionBuilder1.Style.DimensionStyle.LimitFitDeviation = "H"
            radialDimensionBuilder1.Style.DimensionStyle.LimitFitGrade = 7
            nXObject1 = radialDimensionBuilder1.Commit()
        Else
            linearDimensionBuilder1 = workPart.Dimensions.CreateLinearDimensionBuilder(selecteddim)
            linearDimensionBuilder1.Style.DimensionStyle.ToleranceType = Annotations.ToleranceType.LimitsAndFits
            linearDimensionBuilder1.Style.DimensionStyle.LimitFitDeviation = "H"
            linearDimensionBuilder1.Style.DimensionStyle.LimitFitGrade = 7
        End If
    End Sub
    '   function to select dimensions
    Function Select_dim(ByRef obj As NXObject) As Selection.Response
        Dim resp As Selection.Response = Selection.Response.Cancel
            .Subtype = 0
        End With
        Dim cursor As Point3d = New Point3d
        resp = ui.SelectionManager.SelectTaggedObject(prompt, message, _
            scope, selAction, includeFeatures, keepHighlighted, selectionMask_array, obj, cursor)
        If resp = Selection.Response.ObjectSelected Or _
           resp = Selection.Response.ObjectSelectedByName Then
        Else
        End If
    End Function
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Frank Swinkels
Frank I tested Your code, and I get errors that:
[ul]
[li] Annotations.RadialDimensionBuilder is not defined [/li]
[li] Annotations.LinearDimensionBuilder is also not defined [/li]
[li] CreateRadialDimensionBuilder is not member of element NXopen.Annotations.DimensionCollection [/li]
[li] and CreateLinearDimensionBuilder is not member of element NXopen.Annotations.DimensionCollection [/li]
[/ul]
I think, that they add this function in NX 8.5. I regreat that we don't have NX 9 (because We have few 32-bits systems), so I have no possibility to test it. This sub to check if selected object is radial or not is brilliant, I will use it later, after remove some errors.
I also checked in documentation, that RadialDimensionBuilder is in NXopen.Features.
With best regards
Michael
It really would be nice if tolerances that are used frequently could be stored in NX, so they can simply be checked to be applied to the dimension.
Jerry Some time ago I have recorded "macros" to do this job, but (there is always but :)) there are problems:
1) First You have to choose command, instead of dimension. If You choose dimension, then error appears.
2) Macros doesn't work on every computer, even if You have the same version of NX. It seems that there is something not installed on computer, but I couldn't figured out what.
3) Macros are not supported by Siemens.
4) Sometimes after apply tolerance, instead of for example "H7" 3 or 4 square shows, or whole dimension is boldfaced.
That's why I wanna change .macros to .vb. In catia there is a special toolbar where You choose what tolerance You want. It would be a good idea, if NX has it also, but there is a progress, because NX 6 doesn't have possibility to choose "H7", the only option was to click right arrow and write it by Yourself.
Below I attached picture of my toolbar.
Can someone help me with this error: "System.NullReferenceException reference to object wasn't set to occur in object in journal.main() line 29" ?
With best regards
Michael
Here is a journal that works using NX8.5 and just for radius and horizontal dimensions. Hope it helps.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module NX85LimitsFits
    Sub Main()
start1:
        GoTo start1
end1:
    End Sub
        Dim markId3 As Session.UndoMarkId
            Dim radiusDimension1 As Annotations.RadiusDimension = selecteddim
            linearTolerance1 = radiusDimension1.GetTolerance()
            radiusDimension1.SetTolerance(linearTolerance1)
            Dim dimensionPreferences1 As Annotations.DimensionPreferences
            dimensionPreferences1 = radiusDimension1.GetDimensionPreferences()
            dimensionPreferences1.LimitFitDeviation = "G"
            dimensionPreferences1.LimitFitGrade = 6
            radiusDimension1.SetDimensionPreferences(dimensionPreferences1)
        ElseIf dimname1.Contains("Horizontal") = True Then
            Dim horizontalDimension1 As Annotations.HorizontalDimension = selecteddim
            linearTolerance1 = horizontalDimension1.GetTolerance()
            horizontalDimension1.SetTolerance(linearTolerance1)
            dimensionPreferences1 = horizontalDimension1.GetDimensionPreferences()
            horizontalDimension1.SetDimensionPreferences(dimensionPreferences1)
        End If
        nErrs1 = s.UpdateManager.DoUpdate(markId3)
    End Sub
            .Subtype = 0
        End With
        Else
        End If
    End Function
    End Function
End Module
Frank Swinkels
Thanks Frank, it's work perfect. I added rest dimension types, so the journal will work on every case. I also made changes in code to use with unilateral tolerances.
Below I attached my journals, so maybe for some other people will be useful.
Is there any way to select more than one dimension at time?
Once more Thanks everybody for Yours help.
With best regard
Michael
 http://files.engineering.com/getfile.aspx?folder=b15b690c-2e3b-476e-9fe7-9717ca71b2c2&file=macros.7z
I have applied multiple selection to my basic example to show you what is required.
As an alterative can I suggest using a simple dialog. Image 1 shows it for limits and fit entry Image 2 shows it for tolerance values. When the first entry is set to limits and fits it would show the radio buttons for selecting an individual value. If the first entry is set to tolerance I have used a selection list of tolerances. When the desired requirement is set then select Apply and any number of dimension can be selected. After completion the dialog would again be available to set for an other value. If OK is selected it would do any selected dimensions and then exit the program. That is you would only be maintaining and running one program.
Frank Swinkels
 http://files.engineering.com/getfile.aspx?folder=776e59a8-4d8e-45b4-a4c6-e4e036802af7&file=MultipleSelectionDims_FBS.zip.zip
Thanks Frank for Your support.
I changed My code to fits Yours, so now my journals can select more than one dimension at time. I also looked at Your pictures, and decided to create my own version. First I looked on web sites but without success, only I have found was this tread:
http://www.eng-tips.com/viewthread.cfm?qid=328251
I used this thread and some other articles about radio buttons I create my own version. It doesn't work - after I select +-0,01 and hit Ok button, the program go to function select_dims and in this place I can't select anything because form1 is still active, NX stop responding. What I have do is kill process in task manager. I didn't set the rest buttons because if one isn't working it will be a waste of time. What is working is close button :). To create form1 I used Microsoft visual studio 2010 express, because I didn't found sample how to use UIstyler and radio button.
Below I attached my code and modified macros.
With best regards
Michael
Attached you will find three files in the zip file.
One is an NX dialog file (DimTolerances.dlx).
This dialog file must be correctly located. Look in the vb source file for some comments about locating the dialog file
The second is the vb source file (DimTolerances.vb).
It can be run as a journal
The third is an NXOpen executable file (NXDialogTolerances.dll).
It has been signed so that you can execute it.
Frank Swinkels
 http://files.engineering.com/getfile.aspx?folder=eed74c36-2d17-40ea-95aa-2bf50f56affe&file=NXDialogTolerances.zip
Frank thank You for your support, but I cannot open the archive. Probably it's broken.
With best regards
Michael
Thank Frank it's working perfect.
In the meantime I tried change sub to .getDimensionText, and if vale is for example 100 I wanna set dimension text to something. In first part I get error: "Operator "=" is not defined for type 1-dimension table of elements "string" and "integer"." --> line "if x1 = 100 then". When I change it to "if x1 == 100 then", I get error "expression was expected". Second part of code work perfect -> horizontalDimension1.SetDimensionText(text1). I don't know how to solve it.
Code:
    Sub EditDimensionTolerance(ByVal selecteddims () As TaggedObject)
        Dim dimname1 As String = Nothing
        For Each selecteddim As Dimension In selecteddims
            dimname1 = selecteddim.ToString()
		Dim text1(0) As String
		Dim text2(0) As String
		Dim text3(0) As String
		Dim x1() As string
		Dim x2() As string
		text1(0) = "G 1/8''"
		text2(0) = "G 1/4''"
		text3(0) = "G 3/8''"
		Dim Text0 as string
		horizontalDimension1.getdimensiontext(x1, x2)
		if x1 = 100 then
		else
  		horizontalDimension1.SetDimensionText(text2)
		end if
        End If
	Next
    End Sub
With best regards
Michael
You have two code errors in the section
if x1 = 100 then
else
end if
It should be
If x1(0) = "100" Then
Else
End If
That is the variable x1 is an array of strings and we need to get the first line of the array eg x1(0)
The second error is that since x1 is a string array it cannot be checked against a number eg = "100"
Frank Swinkels
