Journal to set/ change dimensions tolerance
niedzviedz
PL
I want create journal to automatically set (or change already setted) dimensions tolerance. The macro must have:
1) possibility to select more than one dimension
2) possibility to reset previously setted value
3) possibility to select different kinds of dimension (radius, diameter, horizontal, vertical, parallel etc.)
I already wrote some of code, by the main problem is that, I don't know how fix selection of more than one dimension, and I can't set values.
Below is my code:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Annotations
Module journal
    Sub Main
	Dim theSession As Session = Session.GetSession()
	Dim ufs As UFSession = UFSession.GetUFSession()
	Dim workPart As Part = theSession.Parts.Work
	Dim displayPart As Part = theSession.Parts.Display
	Dim lw As ListingWindow = theSession.ListingWindow
	Dim theAnnotationManager as NXOpen.Annotations.AnnotationManager = workPart.Annotations
	'Dim theAnnotationManager as AnnotationManager = workPart.Annotations
	Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager
	Dim noteDim As Annotation
	Dim Dimension1 As Annotations.Dimension
	Dim response1 As Selection.Response = Selection.Response.Cancel
	response1 = select_Dim("Select a Curve", noteDim)
	If response1 = Selection.Response.Cancel Then
		Return
	End if
' this code is coped from recorded journal
	Dim linearTolerance1 As Annotations.LinearTolerance
	linearTolerance1.LimitFitDeviation = "g"
	linearTolerance1.LimitFitGrade = 6
	Dimension1.SetTolerance(linearTolerance1)
    End Sub
    Function Select_dim(ByVal prompt As String, ByRef obj As annotation)
        Dim message As String = "Select dimensions"
        Dim title As String = "Selection"
	Dim ui As UI = NXOpen.UI.GetUI
	Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
'        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
	Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim selectionMask_array(0) As Selection.MaskTriple
	Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        With selectionMask_array(0)
            .Type = UFConstants.UF_dimension_type
            .Subtype = 0
            .SolidBodySubtype = 0
        End With
	Dim cursor As Point3d = Nothing
        Dim resp As Selection.Response = _
        ui.SelectionManager.SelectObject(prompt, message, _
            scope, _
            SelAction, _
            includeFeatures, keepHighlighted, selectionMask_array, obj, cursor)
	If resp = Selection.Response.Ok Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY
    End Function
End Module
This journal must set dimension tolerance to "g6", but after selecting do nothing.
Could someone can help me improve this code?
with best regards
Michael
Thanks Frank, once again, for Your support. I tried many combination, but I didn't think that " " will solve it. Is there any "function" to restore changed value?
Below I attached 2 journals. First adds appended text "M" before dimension, second change specific dimension value to G (from 1/8" - G 1") (British standard pipe parallel). Maybe It will be useful to someone in the future.
with best regards
Michael
 http://files.engineering.com/getfile.aspx?folder=81bbba29-3300-4b4e-881a-3a10c938b134&file=Threads.7z
Where do I put the DimTolerances.dlx? Sorry for the question. I run Siemens NX for at least a few weeks.
You have to create system Environment variable:
value x:\user_dir
And in this dir You have to create dir: application, where You put this file. Everything is written in the vb file. Bellow I quote this comment:
Code:
        '------------------------------- DIALOG LAUNCHING ---------------------------------
        '    Before invoking this application one needs to open any part/empty part in NX
        '    because of the behavior of the blocks.
        '    Make sure the dlx file is in one of the following locations:
        '        1.) From where NX session is launched
        '        2.) $UGII_USER_DIR/application
        '        3.) For released applications, using UGII_CUSTOM_DIRECTORY_FILE is highly
        '            recommended. This variable is set to a full directory path to a file
        '            containing a list of root directories for all custom applications.
        '            e.g., UGII_CUSTOM_DIRECTORY_FILE=$UGII_ROOT_DIR\menus\custom_dirs.dat
        '    You can create the dialog using one of the following way:
        '    1. Journal Replay
        '        1) Replay this file through Tool->Journal->Play Menu.
        '    2. USER EXIT
        '        1) Create the Shared Library -- Refer "Block UI Styler programmer's guide"
        '        2) Invoke the Shared Library through File->Execute->NX Open menu.
with best regards
Michael
Thank you very much for your help. It works now.
