RFreund
- Aug 14, 2010
- 1,885
I typically like to reinforce existing joists with the detail that I have attached. It is a little different than just reinforcement the top/bott chords and web members in that it doesn't directly reinforcement the webs. Rather it uses additional web members. Now the analysis that is typically used in these cases, is an analysis using the existing geometry and section to determine the forces in the chords/webs. Then reinforcement is provided to enhance the member section properties. The problem usually is - the shear forces still need to be transferred through existing welds. The attached detail does not rely on existing welds as the new webs are welded to the new chords.
Does the "traditional" approach still seem valid. Meaning if you solve for the force in the chords - reinforcement the top/bottom chords appropriately based on the new built up section. Then size the new web member to take its share of the web force and transfer this into the top/bottom chord? Part of thinks this approach is fine, but part of me thinks the detail looks more like the situation of a flitch beam where the new "truss" will take load in proportion to it's stiffness. In which case the point of where to discontinue the reinforcement seems to get cloudy. Maybe I am over thinking this...
LINK
EIT
LINK
EIT
