Isometric views for 3d drawings
DCGmustangs
1
I am wanting to get information on whether ANSI accepts balloon (item numbers) on isometric views. Is this an acceptable practice.
I think you have a misconception of ANSI standards. ANSI doesn't "approve" or "accept" drawings. ANSI/ASME is a standards organization. YOur client will determine what is acceptable for design documents.
If you're referring to instrumentation symbols, it's ISA (Instrument Society of America). Again, this is a standards organization only - they do not care how you use the symbols or in what context.
I have been adding balloons to iso views for years in different fields of engineering and never had a problem with it. I don't know of a spec that says yes or no to doing it.
Many exploded assembly drawingsa re isometric, and I have always seen them with balloons. I think I've ever seen anything that states you can't do this.
[green]"But what... is it good for?"[/green]
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read faq731-376 to make the best use of Eng-Tips Forums?
