I need to melt holes in rubber sheets that are 20" wide by about 1/8" thick. The only way to punch the holes is with heat so they do not close back up. I know there are hot needle hole punch machines but I don't have $50,000 to buy one. So I'm considering building one myself.
This is how I plan to build it... I have a 24" section of 6" ID schedule 40 steel pipe. I need about 5 holes per square inch. I plan to drill about 800 holes in the pipe and put nails through each hole which in turn I will weld to the pipe. The nails will protrude about 1/4" out of the pipe. The nails are about 5/32" in diameter. I'll use a gas torch to shoot a flame into the pipe / drum to get the nails hot enough to melt and perforate the rubber sheets. The pipe will be on a shaft so it can rotate while the rubber sheets are fed between the hot spiked roller and a smooth roller so the rubber is perforated as it is fed through. I'd like to be able to perforate 6 feet of rubber per minute.
Does it sound like this will work? Would it be better to use short nails so inside the pipe the head of the nails are welded to the inner wall of the pipe, or would it be better to use longer nails so the nails inside the pipe can absorb more heat to transfer to the tips of the nails outside of the pipe? Would it be better to use some type of electric heating element instead of gas?
Please help. Thanks!!!!!!
