I'm working on my first concrete building. It's a five story moment frame and has an odd geometry that precludes the use of simplified methods (ACI 8.3.3). The building is shaped like a square with chamfered corners on one side.
I have numerous questions regarding the analysis approach that should be used in the analysis of this building. If anybody could help with any or all of them, that would be great.
Question #1
ACI 8.8.4 says
Resistance to moments at any floor or roof level shall be provided by distributing the moment between columns immediately above and below the given floor in proportion to the relative column stiffness and conditions of restraint.
ACI 8.9.1 says
The live load is applied only to the floor or roof under consideration and the far ends of columns build integrally with the structure are considered fixed.
Does that mean that I only load one floor at a time when determining col & beam moments? Also, does it mean that I pretend the cols above and below the floor are fixed as in "rigid support" or merely fixed to the members that they frame into. If it is the latter, then wouldn't I still have to calculate the moments from all the other floors to determine how much gets transfered into the floor that I'm working on?
Question #2
ACI 8.9.2 says to design to the worst case given by:
Factored dead load on all spans with full factored live load on two adjacent spans and factored dead load on all spans with full factored live load on alternate spans and factored dead load on all spans with full factored live load on alternate spans?
That's fine in two dimensions but, how do I apply it in three dimensions? Would that not require the use of several permutations of loading? Also, I've build a complete computer model of the structure. If I need to use this method, then I will have to basically build a new set of load cases for every single beam. If that's the case, then why even bother with a model.
Question #3
ACI 10.11.1 makes recommendations on what moments of inertias to use in the design of columns. What guidance is there on what moments of inertias to use for getting the maximum moments for beams? Also, what "I" values should be used for the lateral analysis.
If you've read this far, thanks for your patience. Please advise.
Question #1
ACI 8.8.4 says
ACI 8.9.1 says
Question #2
Question #3
