theonlynamenottaken
In reading AISC 360-05 (13th Edition) I'm a bit confused on Chapter J: Design of Connections, section J2.4 Weld Strength. After the basic Rn=FwAw equation there's a statement, "Alternatively, for fillet welds loaded in-plane the... strength... is permitted to be determined as follows." It then goes on to a section outlining the three alternative cases for fillet weld strength, where one can use a 50% strength increase for transversely loaded fillets:
a) linear weld group loaded in-plane through center of gravity
b) weld group that is loaded in-plane and analyzed using an instantaneous center of rotation method
c) fillet weld groups concentrically loaded and consisting of elements that are oriented both longitudinally and transversely to the direction of applied load.
The majority of welds I work with are loaded normal to faying surface; e.g. an eccentric compressive load. So, I have no in-plane load components, just out-of-plane tension and compression.
Can I not take advantage of the 1.50 increase for fillet welds loaded transversely? The blanket statement I quoted above does say "fillet welds loaded in-plane".
My specific, simplified problem: Circular fillet weld, E70xx, 6.63" pipe diameter, 4.6k ultimate compressive force with 78" eccentricity. Pipe being welded to face of flat plate.
Mu = 359 k"
S(@w=1.0) = 38.5 in3 (assuming 3/8" weld size)
Rmax = 9.11 k/in (including reduction from axial compression)
Rnw = 22.27 k/in (without 1.50 increase)
= 33.40 k/in (with 1.50 increase)
w = .41" => 7/16" (without 1.50 increase)
= .27" => 5/16" (with 1.50 increase)
Your thoughts?
Mu = 359 k"
Your thoughts?
