I'm trying to use an interpart expression in a Part family. I can see the expression listed as User Defined but on opening the Part family dialogue I can't see it or find it.
Am I doing something wrong, can I even use interpart expressions within a part family?
As I've not received any advice perhaps I need to explain myself a little better.
The part family I'd like to create has a child component from which I have created an interpart expression - "TCG01000462694/A":ia and then the expression 'Clip_Dia' uses this as a formula.
When I open Part Families I cannot see either expression listed. Should I be able to and if so what am I doing wrong?
For info, I'm using NX6.0.5.3 and Teamcenter 8.3.1
And the tab next to Interpart Modeling = Product interfaces,
there is a pull down menu, Interpart Linking, should stated "Allow Selection of Any Geometry or Expression"
got the same problem. All necessary boxes are checked, but I can´t see the relevant expressions while choosing the parameters for the partfamily.
It´s not a problem to link the dimension via [Diameter1="Part1/-":iameter] in the Expressionsmenu. But how do I insert this into the partfamily excel sheet?
