S
slingblade
Guest
I am modeling a cylinder and solid piston inside it with a shear pin through one side of the cylinder and roughly half way through the piston.
The load is applied on the end of the piston and transfered through the shear pin to the cylinder which is fixed.
The model was a piece of cake but I can't run analysis without the "insufficient contraints" errors.
My cylinder is fixed at the defaul position, the cylinder and shear pin are a sub assembly and are connceted to the cylinder using General->Insert -- connections at the cylinder bore/piston and shear pin/cylinder pin hole.
Any pointers on why I would get this error? I can run the analysis without the piston/pin subassembly by applying the load to the end of the cylinder. This isn't useful exept that I am ussuming the problem lies with the piston/pin connections.
