Installing Pro/Engineer 64 bit
  • Thread starter Thread starter sohrab
  • Start date Start date
S
sohrab
Guest
Hello.I,m mehran from iran.I have bought Pro/Engineer
(w5)64 bit.but i can,t install.please to direct me.thank
you very much.
I assume that you will have a 64 bit machine and the disks.
What have you tried to do -- where is the problem?
I ask because generally it's sticking in the disks and following the instructions.
Hi Mehran,
Usually Pro/Engineer 64 bit should run the Setup in 32bit
platform, though the reconfiguration of Pro/Engineer 64 bit will not take place
in 32bit platform. As 64 bit .bat files do not run 32bit platform.
However if
